SPONSORED CONTENT
Unmatched strength and durability
This article sponsored by Titebond
Titebond TiteGrab Plus Construction Adhesive stands out for its unmatched holding power and durability.
Construction adhesives are essential for bonding building materials, often outperforming traditional glues and even replacing mechanical fasteners like screws, bolts, and nails in many applications. When used in drywall installation, they can reduce—if not eliminate—nail and screw popouts. For floors, they prevent the dreaded “squeaks and creaks.” They’re also quicker, easier, and cleaner than mortar for installing backsplashes, brick veneer, and tile. The same applies to rigid foam insulation. And they’re a perfect choice for trim work like baseboards, chair rails, wainscoting, and crown molding, allowing for fewer visible metal fasteners.
Titebond TiteGrab Plus Construction Adhesive stands out for its unmatched holding power and durability. Designed for both interior and exterior use, it bonds virtually any material with a strong, permanent, waterproof hold. This adhesive won’t shrink or become brittle over time, providing a lasting bond on both porous and non-porous surfaces. By reducing the need for fasteners, TiteGrab Plus not only simplifies installation but also enhances the longevity and appearance of your projects.
Available at building supply stores across Canada.
