SPONSORED CONTENT
Instantly grab and hold materials – even on vertical surfaces
This article sponsored by Titebond
A professional-grade, fast-grab adhesive designed for demanding construction and remodeling applications.
Titebond TiteGrab Plus Construction Adhesive is a professional-grade, fast-grab adhesive designed for demanding construction and remodeling applications. Formulated with advanced polymer technology, it delivers an exceptionally strong instant bond on both porous and non-porous materials, including wood, metal, drywall, concrete, stone, foam board, tile, and painted surfaces. Its standout feature is its ability to hold heavy materials immediately upon application — even on vertical or overhead surfaces — making it ideal for trim, paneling, moldings, mirrors, and tub surrounds.
This adhesive excels in conditions where speed and holding power matter. It eliminates or greatly reduces the need for bracing, clamping, or mechanical fasteners, which speeds up installation time. It can be applied in a wide range of temperatures —from 0°F to 120°F — and is waterproof, freeze-resistant, and low in VOCs (<50 g/L), making it suitable for both indoor and outdoor use.
TiteGrab Plus offers a working time of approximately 5 to 10 minutes, allowing for some repositioning before it sets. Once cured, it forms a durable, flexible bond that resists shrinking and won’t become brittle over time. Application is easy using the included notched nozzle, and cleanup is manageable with acetone or mineral spirits before the adhesive cures.
This product is not recommended for use on certain plastics like polyethylene or for applications involving continuous water submersion or direct flame. Overall, Titebond TiteGrab Plus is a reliable, high-strength construction adhesive that simplifies installation and delivers long-lasting results in professional and DIY applications alike.
