Woodworking Posters
Woodworking Posters, from Canadian Woodworking, are free, easy-to-use reference guides covering essential techniques, tools, and shop safety.
  • Adhesives poster
    Adhesives
    Learn about the seven major types of shop adhesives
    November 17, 2021
  • Moisture meters poster
    Determining moisture content is critical for success in woodworking.
    May 31, 2021
  • Workshop Safety Poster
    Workshop safety
    Woodworking is a lot of fun, as long as you don't hurt yourself. Download this handy poster that you can put up in your workshop for practical tips on workshop safety.
    August 19, 2020
  • Marking Devices Poster
    Marking Devices
    Marking tools are the most fundamental layout accessories in your shop.
    June 22, 2020
  • Measuring Tools Poster
    Measuring Tools
    Using the right tools and accessories you’ll greatly improve your precision, reduce mistakes and use your shop time more efficiently.
    April 23, 2020
  • Specialty Router Bits Poster
    Router Bits – Specialty
    Learn about the basic types of specialty woodworking router bits.
    December 26, 2019
  • joinery router bits poster
    Router Bits – Joinery
    A router equipped with a joinery bit makes quick work of repetitive joinery tasks.
    September 29, 2019
  • Profile and Edge Treatment Router Bits Poster
    Router Bits – Profile/Edge Treatment
    Use these router bits with a fixed base or plunge router or on a router table to create simple or complex edge profiles.
    July 8, 2019
  • Straight Router Bits Poster
    Router Bits – Straight
    The most frequently used type of router bit, essential for cutting grooves, dados and rabbets as well as for mortising.
    May 9, 2019
  • Hand Planes
    Hand Planes
    The quintessential hand tool that every woodworker should learn to master.
    July 13, 2018
  • Bench clamps poster
    Bench Clamps
    These handy clamps help hold your stock securely on a benchtop.
    May 15, 2018
  • Sharpening Poster
    Sharpening
    Sharp tools make for easier, more accurate and more enjoyable woodworking; they require much less effort to use, and the cuts they make are more precise, crisper, and cleaner.
    March 16, 2018
  • Saw Blades Poster
    Saw Blades
    Buying a new table saw blade can be a daunting experience. Use our handy poster to help you select the right blade for the job at hand.
    January 17, 2018
  • Hand Saws Poster
    Hand Saws
    Hand saws are fundamental woodworking tools that enable you to make a wide range of precise cuts.
    January 17, 2018
  • Drill Bits Poster
    Drill Bits
    Learn about the ten major types of woodworking drill bits.
    September 20, 2017
