SPONSORED CONTENT
Metal cutting made easy
If you're looking to make quick, smooth, burr-free chop cuts on mild steel and ferrous metals this is the saw to consider.
The King Canada KC‑8314 is a corded chop saw designed for cutting metal stock in the workshop or on-site.
Powered by a 15‑amp motor, the tool spins a 14″ chop saw blade at 1,450 RPM, churning through ferrous metals such as rebar, angle iron, bar stock and framed tubing — virtually spark-free. The motor pairs with a rugged steel base fitted with vibration-damping foot pads to help improve stability during cuts.
A quick-release vise accommodates workpieces at 90° or beveled at 45°, streamlining setup times. A chip deflector, chip tray, onboard wrench storage, and a large ergonomic trigger handle enhance operator safety and ergonomics. A carry handle enables portability across the worksite. At just under 40 lbs it remains movable while still provides rigidity.
It can handle square stock up to 4-1/8″ square and it has a maximum width of cut of 7-1/4″.
Overall, the KC‑8314 offers straightforward, heavy-duty cutting at a budget-friendly price point. If you’re looking to make quick, smooth, burr-free chop cuts on mild steel and ferrous metals this is the saw to consider.
Comes with a 14″ X 72 carbide tooth TCG/FTG chop saw blade and adjustment hex keys.
