Festool mobile phone charger
Makes it easy and convenient to charge your wireless device - smartphone, headphones, earbuds and the like - using inductive charging or via a USB A or C port.
The new Festool wireless mobile phone charger makes it easy and convenient to charge your wireless device – smartphone, headphones, earbuds and the like – using inductive charging or via a USB A or C port.
Manufacturer: Festool
Model: PHC 18
Price
: $65.00
Made in
: China
Source: Find your dealer
Warranty: 3 years
Key Features:
  • Use it with any Festool 18 V battery (except 3.1 Ah Ergo)
  • Charge up to 3 devices at the same time.
  • Charges wireless devices that support Qi-BPP (5W) or Qi-PPDE (9W) inductive charging.
  • Includes two USB ports – USB-A (5V at 2.4A (12W max) and USB-C (5V at 3.0A (15 W max).
  • Charges up to 8 times per battery charge (connected to a fully charged 5.2Ah Festool battery).
festool charger
At one time or another most of us have had a wireless device – smartphone, earbuds, headphones and the like – run out of battery power. The new Festool charger (PHC 18) makes it very easy to recharge any of these devices.
Attach any Festool battery (except the 3.1 Ah Ergo) to the charger, and if your mobile device uses inductive charging, lay it on top the charger. Within 2 or 3 hours your device will be recharged. It’s a good idea to remove your phone case, especially if it’s metal.
For non-inductive devices there are two USB ports – for either Type A or C cords. Use whichever port accepts your cable.
festool charger
The charger, equipped with a battery, is small enough to take along with you to a job site, on a service call, in car or truck, to the cottage or beach – just about anywhere. You might not get a lot of use out of it, but when you do run out of battery power and a 120V receptacle isn’t close at hand you’ll be happy to have this charger at the ready.
Published September 5, 2022 | Last revised September 29, 2023
