DEWALT Xtreme 5-in-1 Cordless Drill/Driver
An exceptionally versatile and compact, precision drilling and fastening system.
Multi-head drill/drivers with interchangeable chucks have been available for at least the last decade. You’ll find models from Bosch, Festool, Hilti, Metabo and Milwaukee. They’re popular, especially within the trades – electricians, plumbers, HVAC technicians, cabinet installers, renovators and the like – and among avid DIYers and woodworking hobbyists.  The primary reasons is that a single power tool handles a range of tasks that would otherwise require multiple power tools.
What makes these power tools so useful is that you can quickly alternate between drilling and fastening, particularly in tight corners and around obstacles that would be inaccessible with a standard drill/driver. You don’t need to have two separate drills on hand, or to remove the drill bit and attach a driver bit with a drill bit holder. You simply switch drive chucks.
Manufacturer: DeWALT
Model: DCD703F1
Price: $249.00
Warranty: 3 Years (2 years on battery)
Made in: China
Source: Find a Retailer
Battery platform: 12V
Speed: 0 – 425 RPM (low speed); 0 – 1,500 RPM (high speed)
Maximum power: 250 Unit Watts Out
Chucks included: 3/8″ keyless; 1/4″ hex; 1/4″ hex right angle; 1/4″ hex offset
Clutch settings: 15
Includes: drill/driver body; 4 chucks; 12V 2Ah battery; battery charger; belt clip; storage case with plastic organizer
dewalt DCD703F1
Similar to other multi-head units, the DeWALT 5-in-1 consists of a compact drill/driver body that has an integrated 1/4″ hex chuck, and it comes with four interchangeable chucks – a 3/8″ standard keyless chuck, a 1/4″ hex chuck, a 1/4″ right angle drill chuck and a 1/4″ offset chuck. Without an attachment, you can use the DeWALT 5-in-1 as a compact 1/4″ hex screwdriver.
Dewalt 5-in-1 drill driver
I really like the storage bag that comes with this tool. It does a reasonable job of protecting your investment and an excellent job of keeping things organized. The removable plastic tray has compartments for each tool head, the drill/driver, charger, battery and half a dozen drill or driver bits. There is still room in the bag to store several bit and driver sets along with your most frequently used fasteners.
dewalt DCD703F1
The brushless motor is powered by a 12V 2Ah battery (DCB122) with a 24Wh rating that only adds 7-3/4 ounces to the tool weight. The drill/driver only weighs 2lbs 3oz (with battery installed). Each head adds about another 8oz of weight.
dewalt DCD703F1
The battery has an on-board fuel status gauge so you know when to recharge. The included charger (DCB112) takes just under an hour to recharge the battery (it will also charge 20V batteries). A single battery may be ok for DIYers, but tradespeople will likely want to purchase an additional 12V battery (unless you have other DeWALT 12V tools on hand). I’d opt for a 3Ah battery (DCB123), which will give you about 50% increase in runtime.
There are 2 speed settings on this tool and 15 clutch setting plus a drilling-only mode. I typically keep it in the high-speed setting, dropping down only when I’m setting larger fasteners.
dewalt DCD703F1
The DeWALT 5-in-1 delivers 250 UWO (unit watts out) of power. It’s impossible to convert this to inch pounds of torque (the standard used by virtually all other tool manufacturers). In comparison, the DeWALT DCD780C2 20V MAX drill/driver delivers 350 UWO of power (about a 40% increase). I typically use #8 screws up to 2-1/2″ in my shop and pre-drill countersink holes. The largest holes I freehand drill are 3/4″ diameter.  The DeWALT 5-in-1 has both ample torque and speed for these tasks.
The LED light is fairly bright and does a good job of lighting the work area and it stays on for about 15 seconds after the trigger is released.
dewalt DCD703F1
While the DeWALT 5-in-1 does have a convenient belt clip, tools like this are constantly being placed (dropped) on work surfaces – often coarse surfaces. Fortunately, on both sides of the casing (head and base) are large rubber pads that protect the drill when laid on its side.
The chuck heads are easy to install and remove. To install a chuck you pull back on a gray spring-loaded locking ring on the chuck, insert it onto the drill/driver head, and then release the locking ring. Reversing the sequence removes the chuck head. On all the chucks except the 3/8″ keyless chuck, and on the drill/driver head are a series of 16 metal tabs that interconnect. This enables you to position the chuck heads at 22.5° increments.
dewalt DCD703F1
dewalt DCD703F1
Most of the time I alternate between the 3/8″ keyless chuck and the 1/4″ kex chuck. I leave a drill bit in the keyless chuck and the corresponding driver bit in the hex chuck. Switching between the two takes less than 4 seconds. The offset chuck is surprisingly useful, as it enables you to drill and sink fasteners up to 1/2″ from a vertical surface. While I rarely use the right angle attachment it’s a godsend when needed. Plus, it can be combined with any of the others chuck when you need access to tight or awkward spaces.
dewalt DCD703F1
If you’re looking for a light weight, versatile drill/driver that you can use in just about the most awkward places you’re likely to encounter, then the DeWALT 5-in-1 is well worth considering. It’s no wonder that the DeWALT 5-in-1 was voted a runner-up in the 2021 Tool of the Year awards power tool category.
Published December 14, 2021 | Last revised October 31, 2025
4 thoughts on “DEWALT Xtreme 5-in-1 Cordless Drill/Driver”
  1. I’m unclear what this means “The offset chuck is surprisingly useful, as it enables you to drill and sink fasteners up to 1/2″ from a vertical surface.” – Specifically, “up to” part. Do you mean the closest you can get to a vertical surface is 1/2″? Its just the way its phrased makes me think you can get closer than 1/2″ to a vertical surface. Thanks!
    I’m trying to find out of the Dewalt can get any closer than its competitors.
    • Hi John. ‘Made in China’ used to be a moniker for ‘crap product’. But it’s certainly not the case for all products any longer. While it is obvious that some products are still poorly made, a lot of the brand name products made in China are built to a company’s exact specifications in highly automated manufacturing plants. Hilti power tools – the ‘go-to’ power tools in the construction sector – are made in China. Hilti, Bosch, Makita, Milwaukee all have tools made in China. So do Sony, Samsung, Canon, Microsoft, Ray Ban, Nike, Levi’s and a host of others. We may not like it, but them’s the facts.
