SPONSORED CONTENT
Mini-Mite 3 PLATINUM system
This article sponsored by Fuji Spray
The award-winning Fuji Spray Mini-Mite 3 PLATINUM Turbine packs enough power and portability to help you tackle all your fine-finishing projects.
Professional woodworkers and cabinetmakers: Fuji has you covered. The award-winning Fuji Spray Mini-Mite 3 PLATINUM Turbine packs enough power and portability to help you tackle your fine-finishing projects, allowing you to use a range of high and low viscosity materials to spray virtually any substrate imaginable. Equipped with Fuji Spray’s Heat Dissipation Chamber and Noise Reduction Covers to effectively balance heat and sound from the turbine, the Mini-Mite 3 PLATINUM is the perfect balance to achieving the perfect finish you need, every time.
