SPONSORED CONTENT
Magnum Industrial 14” Wood Bandsaw
This article sponsored by KMS Tools
The Magnum MI-91340 bandsaw is a real workhorse with a powerful 1.5 HP motor that can be wired to 220 volts for extra power if re-sawing large boards.
The Magnum MI-91340 bandsaw is a real workhorse with a powerful 1.5 HP motor that can be wired to 220 volts for extra power if re-sawing large boards. You can select between two motor speeds (1,630 and 2,730 RPM) for resawing or non-ferrous metal cutting. Dynamically balanced wheels ensure vibration-free cutting and a standard easy-to-adjust guide system makes blade changeover quick and easy. The MI-91340 delivers a maximum cutting width of 13-5/8” and height of 6”. The 16” × 16” cast-iron table tilts 0° to 15° to the left and 45° to the right.
