Cherry Wood Bowl
Cherry Wood Bowl
Maker: Terry Mader
Submitted: July 2024
Cherry wood bowl hand shaped using hand saws, hand planes, gouge and spoon chisels, flap discs on angle grinder, rasp files, shaped scraper blades. The inlay is completed with hand cut pieces of padauk. The pieces are set into a recess created using drill bits with depth stops and chisels. They are then glued in. The knob is Jatoba. The finish is teak oil and hand waxed.
