Wooden cube puzzle
Rea Gibson
The seven shapes in this puzzle represent all the ways three or four cubes can be arranged, other than in a straight line.
These shapes go together to make a solid cube, as shown, but can be arranged to make dozens of other interesting shapes.
When there is a set of these shapes in a toy box, it is an excellent way of nurturing a child’s grasp of spatial relationships.
Wooden cube puzzle
Cut out twenty-seven ¾” square blocks and glue together as shown – then the project is complete.
Now comes the hard part: put the variously shaped pieces together to form a solid cube. (We used ¾” blocks but you can make your cube puzzle pieces any size you like.)
Find the solution here.
There are only 26 blocks in the pics above, not 27?
The link to the solution does not take you to the solution?
Hi John: There are 27 blocks – but one is not visible in the drawing. It’s on the 3rd row, 2nd column – three blocks are shown; the 4th is in the back, bottom. You’ll find the solution here: click on the Solution tab.
