Build a temporary mitre saw stand
Mark Salusbury
Find more Shop projects
When trimming a reno site, I needed a quick, cheap, temporary base to support my mitre-saw so I could tame baseboard, quarter round and other stock mouldings, some 16' long and often at the extreme ends. My solution was to use three 8' long 2 × 4s to make a super-simple workstation I could clamp to some on-hand work stands.
When trimming a reno site, I needed a quick, cheap, temporary base to support my mitre-saw so I could tame baseboard, quarter round and other stock mouldings, some 16′ long and often at the extreme ends. My solution was to use three 8′ long 2 × 4s to make a super-simple workstation I could clamp to some on-hand work stands.
The 8′ rails were fine, but I would have used 10′ or even 12′ rails for extra support if I had had them. The length of the spacer blocking to fit between the rails was determined by the depth of the mitre-saw base and the screw-hole locations for fastening the saw down. The center of the holes was equal to the center-to-center distance of the long 2 × 4s. Just like assembling a stud wall, the rails were screwed to the blocks with 3″ construction screws.
Once assembled, clamped to stands and the saw fastened centrally, I measured the height of the saw’s working surface above the top surface of my support assembly (3″ for me), added the width of my support stock (3-1/2″), and cut blocks from scrap wide enough to support the trim I was preparing to cut. Two or three on each side of the saw supported even floppy quarter round. Short +2″ × 2′ long auxiliary fences suited my needs, but could have been longer or taller as required to offer adequate support for the stock to be safely and accurately cut.
Once the job was over, the parts were unclamped and disassembled, the screws went back in the tub and the 2 × 4 lumber was set aside for the next build.
A few 2 × 4s are all you need to make this quick and temporary mitre saw stand for your next trim project. Your back will thank you.
Photos by Mark Salusbury
